I have been trying sending midi from 18x to a Sparkfun VS1103 breakout board.
I started using Hippys midiuart.txt prog and all appeared to work Ok. Midiuart actually plays a tune in a loop going through all the midi sounds. Waht I want to do is switch on 18x then send program change to setup a sound then play the sound as I press pushbuttons on demand, not in aloop. I discovered the sending just one program change code followed by prognumber did not work, I needed to send at least twice before it reliably played.
Was wondering is this mormal because of the Peek and Poke etc. Does the ausart need to do something to get started ???
Any ideas, Thanks......
