Try it & see, although it'll be an overkill at such ratings,which look more PV solar panel suited, & I suspect the switch on voltage may be rather too high for the job. Compare specs. yourself?
I guess you appreciate that almost any Schottky diode should do here, as only tiny currents (a few mA) are flowing & it's the low forward voltage drop rating ( ~.1 -.3V) that's being utilized. Normal Si diodes are ~0.6-0.7V of course. Other Schottky attributes, such as high speed & low junction capacitance, are pretty academic in this PICAXE enhancement context.
