Surely there is an error in the diagram on page18 in section 3. for the stepper motor circuit.
Pins 1 and 8 show it at +V2 although inside the L293D layout it shows Pins 1,9 and 16 at 5v.
Project board power information shows that +V1 (+5v) is used to to run the Picaxe and with the resistor removed a 2nd
supply labeled +V2 can be used (12v).
Data sheet info for the L293D shows that the max voltage for Pins 1 and 9 (enable) is 7 volts.
Looking at past posts quite a few chips were fried by tying all to a higher votage, mine were... ( have to read the small print in future).........
rj
rj
