L LizzieB Senior Member Mar 11, 2007 #1 Is there any example code available for using the ltc1298 with an 08M ?
hippy Technical Support Staff member Mar 11, 2007 #2 The code in this Application Note for the Basic Stamp I should provide the basics of what you are after, although you might need to change I/O assignments and make a few other changes. www.basicstampiii.com/dl/docs/prod/appkit/ltc1298.pdf
