This question came up in another forum and got me pondering.
You have a 5v system.
You have a motor rated at 3V max (max draw at stall is between 1-2A).
You want to drive the motor both forwards and reverse within your 5v system, but deliver only 3v to the motor.
If it were unidirectional, I could see several simple fixes Like powering it through a diode or two in series. But that does not work for going the other direction. Perhaps an H-bridge or similar arrangement would provide a similar drop, but allow bi-directionality?
I also though of running off couple of resistors set up as a voltage divider, but if you run the resistors across V+ and V- and run the motor off tap and V-, then in the other direction, you would be running the motor off tap and V+. I am thinking that would not work.
Any other thoughts out there?
Cheers,
Wreno
Cheers,
Wreno
