Im looking into the possibilities of using a Picaze 28X1 to control an unusual central heating system.
Because of the nature of the system a lot of the inputs and outputs need to be 230v AC with a maximum peak load of 0.2A. (4 mains inputs, 3 mains outputs)
I was considering using relays to change the 230V AC down to the 5V required for the PIC. However, there must be a simpler and less "mechanical" solution considering I am not actually drawing a whole lot of current from the control system.
Can anyone suggest a suitable method of isolating the logic control signal from the 230V down to 5?
Was thinking about using Photomos relays...rapidelectronics part number 60-4320 for the outputs but not so sure about the inputs
My only other concern is how reliable the PIC will be in a control system such as this? once its set running will it keep on going for years to come, or is using a PIC for such a vital task not really the best of ideas?
Any input greatly appreciated.
