The idea of that is that you use the EEPROM command in a data cell to preload up to 256 bytes of EEPROM with data and the variable (e.g. A) that you select for the EEPROM location to read from is the variable that contains the address you want to read so you can put it in a loop and use whatever variable is being used for the loopcounter.there's just an Eprom read table with single digit variable, or am missing something.
eeprom 16,($3F,$06,$5B,$4F,$66,$6D,$7C,$07,$7F,$67)
