lookup command.
kinder
Hi there,
I was wondering if anyone knew of an issue with the BASIC 'lookup' command in the program compiler. I have been trying to simulate driving a Unipolar stepper motor using a PICAXE 08 and L293 chip. The program is listed below. The Picaxe 08 doesn't seem to be operating correctly - i.e the output are not being set after the lookup command selects them from the list of Hex numbers. The program simulates perfectly well using Picaxe programming editor, but seems to fall down using VSM.
Any help would be greatly appreciated.
thanks.
symbol singlestep = 4
symbol halfstep = 8
symbol delay = 1000
symbol stepcount = b0
symbol counter = b1
output 1
output 2
output 4
for counter = 1 to 20 'single step forward
for stepcount = 1 to singlestep
lookup stepcount, (0,$01,$02,$04,$10), pins
pause delay
next stepcount
next counter
pause 2000
bgrabowski
Try using a different variable instead of 'pins' in the lookup line (say b9), then on the next line put 'let pins = b9'
kfahrner
I am having the same issue, trying to control a 7 segment LED display using lookup. I am using code from David Lincoln's 'Experiments in Mechatronics' (2003), page 38. The critical line is:
lookup digitout, ($BE, $82, $DC, $D6, $E2, $76, $7E, $92, $FE, $F2), outbyte
Variables 'digitout' and 'outbyte' have both been defined with symbol statement. I have tried to replace them by direct references to b0 - b8 variables and everything else I could think of - to no effect. All other variables compute properly when stepping through. I have also checked that 'digitout' contains a valid numeric between 0 and 9 before stepping into lookup, but 'outbyte' remains 0.
animal2
Lookup does not work properly at the moment
i had same problem
Technical gave me this temporary solution
ORIGINAL CODE
'for counter=0 to 5
'lookup counter, ($33,$32,$28,$0C,$01,$06), outbyte
'gosub lcdout
'next counter
USE THIS FORMAT INSTEAD
outbyte = $33
gosub lcdout
outbyte = $32
gosub lcdout
outbyte = $28
gosub lcdout
outbyte = $0C
gosub lcdout
outbyte = $01
gosub lcdout
outbyte = $06
gosub lcdout
kfahrner
Thanks for the tip. In contrast to the step motor application, I need to look up only one of the byte codes at a time. This required a few additional conditional statements, but it all works now. I expect the lookup command will be fixed in due course with the first official release.
Kind regards Klaus
