Logicator has a COUNT function, the result of which is assigned to a variable (A>T). As these variables are single byte (0-256) I would assume that the full 2 byte (0-65535) range available if programming in BASIC is not available. The variable assigned in Logicator would contain just the lower 8 bits of the result.
Can someone confirm this?
