logic AND OR
tim griff
Dear All,
20m2 picking up d1 d2 d3 d4 from GSM modem .
These will be four character words NORM, HOUR, FLIP
the PE passes the syntaxon the code below as correct, but "passes" if only the first character is correct. I'm trying to allow both uppercase and lowercase characters
I must be making a school boy error, and I've looked at this too long
regards
Tim
norm_test:
if d1 = 78 or d1 = 110 AND d2 = 79 or d2 = 111 AND d3 = 82 or d3 =114 AND d4 = 77 or d4 = 79 then goto pre_norm
hour_test:'hour
if d1 = 72 or d1 = 104 AND d2 = 79 or d2 = 111 AND d3= 85 or d3= 117 AND d4 = 82 or d4 = 114 then goto pre_hour
flip_test:'flip
if d1 = 70 or d1 = 102 AND d2 = 76 or d2 = 108 AND d3= 73 or d3= 105 AND d4 = 80 or d4 = 112 then goto pre_flip
pre_norm:
pre_hour:
pre_flip:
It's a bad idea to mix AND and OR in an IF statement and can often lead to things not working. The best solution is to convert lower to upper than check the uppercase, and use ASCII characters where it makes things more readable and understandable ...
If d1 >= "a" And d1 <= "z" Then : d1 = d1 - "a" + "A" : End If
If d2 >= "a" And d2 <= "z" Then : d2 = d2 - "a" + "A" : End If
If d3 >= "a" And d3 <= "z" Then : d3 = d3 - "a" + "A" : End If
If d4 >= "a" And d4 <= "z" Then : d4 = d4 - "a" + "A" : End If
If d1 = "N" And d2 = "O" And d3 = "R" And d4 = "M" Then ...
If d1 = "H" And d2 = "O" And d3 = "U" And d4 = "R" Then ...
If d1 = "F" And d2 = "L" And d3 = "I" And d4 = "P" Then ...
tim griff
Thanks hippy this works well, I'm sure I would not have come up with this!! Tim
BESQUEUT
+1
Another way to write the same thing :
[color=Blue]symbol [/color][color=Purple]d1[/color][color=DarkCyan]=[/color][color=Purple]b1[/color]
[color=Blue]symbol [/color][color=Purple]d2[/color][color=DarkCyan]=[/color][color=Purple]b2[/color]
[color=Blue]symbol [/color][color=Purple]d3[/color][color=DarkCyan]=[/color][color=Purple]b3[/color]
[color=Blue]symbol [/color][color=Purple]d4[/color][color=DarkCyan]=[/color][color=Purple]b4[/color]
[color=Black]main:[/color]
[color=Blue]do
      [/color][color=Blue]if [/color][color=Purple]d1 [/color][color=DarkCyan]= [/color][color=Red]"N" [/color][color=DarkCyan]or [/color][color=Purple]d1 [/color][color=DarkCyan]= [/color][color=Red]"n" [/color][color=Blue]then
            if [/color][color=Purple]d2 [/color][color=DarkCyan]= [/color][color=Red]"O" [/color][color=DarkCyan]or [/color][color=Purple]d2 [/color][color=DarkCyan]= [/color][color=Red]"o" [/color][color=Blue]then
                  if [/color][color=Purple]d3 [/color][color=DarkCyan]= [/color][color=Red]"R" [/color][color=DarkCyan]or [/color][color=Purple]d3 [/color][color=DarkCyan]=[/color][color=Red]"r" [/color][color=Blue]then
                        if [/color][color=Purple]d4 [/color][color=DarkCyan]= [/color][color=Red]"M" [/color][color=DarkCyan]or [/color][color=Purple]d4 [/color][color=DarkCyan]= [/color][color=Red]"m" [/color][color=Blue]then
                              [/color][color=Green]' pre-norm code
                        [/color][color=Blue]endif
      if [/color][color=Purple]d1 [/color][color=DarkCyan]= [/color][color=Red]"F" [/color][color=DarkCyan]or [/color][color=Purple]d1 [/color][color=DarkCyan]= [/color][color=Red]"f" [/color][color=Blue]then
            if [/color][color=Purple]d2 [/color][color=DarkCyan]= [/color][color=Red]"L" [/color][color=DarkCyan]or [/color][color=Purple]d2 [/color][color=DarkCyan]= [/color][color=Red]"l" [/color][color=Blue]then
                  if [/color][color=Purple]d3 [/color][color=DarkCyan]= [/color][color=Red]"I" [/color][color=DarkCyan]or [/color][color=Purple]d3 [/color][color=DarkCyan]=[/color][color=Red]"i" [/color][color=Blue]then
                        if [/color][color=Purple]d4 [/color][color=DarkCyan]= [/color][color=Red]"P" [/color][color=DarkCyan]or [/color][color=Purple]d4 [/color][color=DarkCyan]= [/color][color=Red]"p" [/color][color=Blue]then
                              [/color][color=Green]' pre-flip code
loop[/color]
BESQUEUT
[color=Navy]#macro [/color][color=Black]ToUpper[/color][color=Blue]([/color][color=Black]Letter[/color][color=Blue])
If [/color][color=Black]Letter [/color][color=DarkCyan]>= [/color][color=Red]"a" [/color][color=DarkCyan]And [/color][color=Black]Letter [/color][color=DarkCyan]<= [/color][color=Red]"z" [/color][color=Blue]Then [/color][color=Black]: Letter [/color][color=DarkCyan]= [/color][color=Black]Letter [/color][color=DarkCyan]- [/color][color=Red]"a" [/color][color=DarkCyan]+ [/color][color=Red]"A" [/color][color=Black]: [/color][color=Blue]End If[/color]
[color=Navy]#endmacro[/color]
[color=Blue]do
      [/color][color=Black]ToUpper[/color][color=Blue]([/color][color=Purple]d1[/color][color=Blue])
      [/color][color=Black]ToUpper[/color][color=Blue]([/color][color=Purple]d2[/color][color=Blue])
      [/color][color=Black]ToUpper[/color][color=Blue]([/color][color=Purple]d3[/color][color=Blue])
      [/color][color=Black]ToUpper[/color][color=Blue]([/color][color=Purple]d4[/color][color=Blue])
      [/color]
There are typically more than one way to skin the proverbial cat. As some alternatives to hippy&#8217;s code example to convert lower case to upper case:
Could alternatively become
If d1 >= "a" And d1 <= "z" Then : d1 = d1 AND $DF : End If ; mask bit 5 out
or
If d1 >= "a" And d1 <= "z" Then : d1 = d1 - $20 : End If ; clear bit 5
Both of which will mask / clear bit 5 thereby converting lower case to upper case.
