The following is a overview of the LM75A.
Picaxeforum helped me with the code so I see it only fair to put this back into picaxe forum for others.
The chip is fairly easy to use as the MSB from register 0 is the temp.
Getting Started
Datasheet:
http://www.datasheetcatalog.org/datasheet/philips/LM75A_1.pdf
The following code is to read a temperature via I2C at address 0 positive only:
i2cslave %10010000, i2cslow, i2cbyte ;Set ReadI2C to read from address 0
The following is to set a alarm temperature of 23c with a hysteresis of 21c
This will pull pin 3 of the IC down from 5v to 0v refer to datasheet
Pin 3 IC is connected to IN0 of Picaxe. Positive Only.
The following is to read 2 devices. Positive Only
The following code is for one device negative and 3 decimal points (thanks hippy)
Complete code
Here is my working temp reader with 18x. This uses the poor mans LCD and one LM75a.
Enjoy,
Derek L
Getting Started
Datasheet:
ReadI2c 0,(b1,b0)
SerTxd ("Temperature is ", #b1,13,10)
writei2c 3,($17,00) ;Set Alarm Temperature of 23degC
writei2c 2,($15,00) ;Set Alarm Pullout temp of 21degC
ReadI2c 0,(b1,b0) ;Read register 0 to w0 (b1, b0)
SerTxd ("Temperature is ", #b1," ")
if pin0 = 1 then
SerTxd ("Temp Good", 13, 10)
SerTxd ("Temp Bad :(",13,10)
end if
i2cslave %10010000, i2cslow, i2cbyte ;Address 0
readi2c 0,(b1,b0)
i2cslave %10011000, i2cslow, i2cbyte ;Address 1
readi2c 0,(b3,b2)
SerTxd("Probe 1 is ",#b1, " Probe 2 is ", #b3, 13, 10)
That's quite a handy format; the decimal point is at the boundary of the two bytes and the msb of the high byte is the sign bit, so rough and ready ( all untested ) ...
If you want trailing zeroes, change the SerTxd to ...Code:If w0 < $8000 Then SerTxd( "+" ) Else w0 = -w0 SerTxd( "-" ) End If w1 = b0 / 32 * 125 SerTxd( #b1, ".", #w1, CR, LF )
If you want trailing zeroes removed ...Code:SerTxd( #b1, ".", #w1 ) If b0 = 0 Then : SerTxd( "00" ) : End If SerTxd( CR, LF )
Code:If w1 <> 0 Then Do b0 = w1 // 10 If b0 = 0 Then : w1 = w1 / 10 : End If Loop while b0 = 0 End If SerTxd( #b1, ".", #w1, CR, LF )
Complete code
readi2c 0, (b1,b0)
If w0 < $8000 Then ;Check for Sign Bit (B1 bit 15)
SerTxd( "+" )
Else
w0 = -w0
SerTxd( "-" )
End If
w1 = b0 / 32 * 125 ;Decimal reading, shift value and multiply by accuracy (0.125 deg)
SerTxd( #b1, ".", #w1, 13, 10)
;Documentation
;Pinout is as following: From the Picaxe, Out0 -> LCD DB4, Out1 -> LM75A SDA Pin1
;Out2 -> LCD RS, Out3 -> LCDE, Out4 -> LM75A SCL Pin2, Out5 -> LCD DB5
;Out6 -> LCD DB6, Out7 -> LCD DB7
'============ PINS ===================================================
symbol lcde = 3
symbol LCDData = %00000100
symbol LCDInst = %00000000
'============ END PINS =================================================
'============ DECLARATIONS ==============================================
symbol OutByte = b0
symbol RS = b1
symbol counter = b2
symbol Temp1Byte = b3 'Temp1Byte status byte %00000000, =n,n,n,n,n,n,is zero, sign value
symbol Temp1MSB = b5
symbol Temp1LSB = b4
symbol Temp1Word = w2
symbol Temp1Decimal = w3
'============ END DECLARATIONS ========================================
'============ INITS ================================================
RS = LCDInst 'Init LCD
for counter = 0 to 5
lookup counter, ($33, $32, $28, $0c, $01, $06), OutByte
gosub LCDOut
next counter
i2cSlave %10010000, i2cSlow, i2cByte
'============ END INITS ===============================================
'============ MAIN ===============================================
lcdstatic:
for counter = 0 to 2 'Moves LCD cursor to line 1, char 0
RS = LCDInst 'SET RS to LCDInst must be in loop because RS gets changed
lookup counter, ($80, $06), OutByte
RS = LCDInst
gosub LCDOut
next counter
for counter = 0 to 14
RS = LCDData 'Set to data mode
lookup counter, ("Current Temp is"), OutByte
gosub LCDOut
next counter
RS = LCDInst
lookup counter, ($C8, $06), OutByte
gosub LCDOut
next counter
RS = LCDData
lookup counter, (%11011111,"C"), OutByte
gosub LCDOut
next counter
gosub i2ctemp
gosub lcdtemp
'============ END MAIN ===============================================
'============ SUBS =============================================
i2ctemp:
ReadI2c 0,(b5,b4)
'Temp1Word = $649 * 32 'simulate a temperature
If Temp1LSB = 0 Then
Temp1Byte = Temp1Byte or %00000010 'Give "=zero" temp1byte
Else
Temp1Byte = Temp1Byte and %11111101 'Isolate zero value
End If
If Temp1Word <= $8000 Then
Temp1Byte = Temp1Byte or %00000001 'Give Temp sign
Else
Temp1Word = -Temp1Word 'Convert to Negative
Temp1Byte = Temp1Byte and %11111110 'Isolate Temp sign set to zero
End If
Temp1Decimal = Temp1LSB / 32 * 125 'Shift 5 spaces and times by 125 (resolution)
lcdtemp:
RS = LCDInst
lookup counter, ($C6, $04), OutByte
gosub LCDOut
next counter
if Temp1Byte <= 1 Then
Temp1Decimal = Temp1Decimal / 10 'Isolate to 0.xx
OutByte = Temp1Decimal // 10 + $30
RS = LCDData
gosub LCDOut
loop while Temp1Decimal > 10 'Run to 0.xx if value was 0 would get 0.0x(x) missing
RS = LCDData
lookup counter, ("00"), OutByte
gosub LCDOut
next counter
end if
RS = LCDData
OutByte = "."
gosub LCDOut
OutByte = temp1msb // 10 + $30
RS = LCDData
gosub LCDOut
'if temp1msb = 0 then exit
temp1msb = temp1msb / 10
loop while temp1msb > 0
RS = LCDData
If Temp1Byte = 1 or Temp1Byte = 3 then 'Temp1Byte sign value
Outbyte = "+"
Else
Outbyte = "-"
Endif
gosub LCDOut
LCDOut:
RS = OutByte / 16 & 1 | RS ; Move MSB DB4 to bit 0
pins = OutByte & %11110000 | RS ; Put MSB out fiRSt
PULSOUT lcde, 1 ; Give a 10uS pulse on E
RS = RS & %00001100 ; Clear bits 3 and 4
RS = OutByte & 1 | RS ; Move LSB DB4 to bit 0
pins = OutByte * %00010000 | RS ; Put LSB out second
'========= END SUBS =============================================
Enjoy,
Derek L
