hi, i am planning on making a dot matrix pong game(two paddles and a ball which you batt around) testing my game using the simlation i have just seen that it is very easy due to it being almost square 7x8 matrix so i thought maybe i could hook up two matrix using all of the same code (apart from one of the paddles) and use another picaxe to monitor the center (2 of the the first and last row of each matrix )rows and columns on my dotmatrix this would use all 16 off the inputs 7 verticle and 1 for the column on each dot matrix and use that picaxe to see if any of the led are on and then send a output to the other domatrix which will continue the ball moving across the sceen and depending on which verticle led it is on hold the output on or that amout of pauses to tell the dotmatrix where to start the ball
crazy idea just wondering if it was possible maybe for a future project
thanks
i might need 2picxe to monitor the dotmatrixs as i will need to see two columns to see if the ball is moving up or down aswell as across
thanks
