Line breaks in terminal window
BobWhite
Is there away to break lines in the terminal widow?
Most terminal programs will display the proceeding characters on a new line after either a carriage return/linefeed (ascii 10 and 13) or a carriage return.
The terminal window does not. This makes it difficult to see the transmitted data.
If this is not possible in the current version it would be a nice addition to the next version.
When I have used SERTXD with CR and LF keywords (these have pre-defined values in the Programming Editor), the terminal window does go to a new line.
Can you please post your program code so forum members can investigate for you or give you guidance
