TerryBarnaby identified an issue with the 28X1 that receiving serial data after issuing a HSERSETUP appears to alter PWMOUT settings.
therowes has a problem using high speed serial in conjunction with HI2C.
southernbob noted that SERVO stops background processing when TUNE or PLAY execute on a 14M, and someone else reported SEROUT problems on anything other than Pin 0.
Not sure what issues Jeremy encountered, if any.
Where there are design issues - SERVO must stop while SERIN executes - which create limitations - SERIN cannot be used if you want SERVO to keep running glitch free - these are normally identified in the manual, or should be. Occasionally things will get missed out but hopefully updated later.
For unexpected behaviour, they can only be classed as bugs or limitations after investigation by Rev-Ed, then fixed or documented later.
It would be nice to have a detailed list of known bugs and missing functionality in various firmware versions. The only thing available at present is <i>firmware.txt </i> and that requires a some guesswork to determine what a particular version did not do with respect to what the manuals describe.
