I have a board from EFX-TEK. My concern is the serout command. Below is the paragraph for it FC 4 Command protocol: The FC-4 serial connection conforms to the Parallax AppMod bi-directional communications protocol, which operates at TTL (0 to 5 VDC) using "open-true baud mode to enable daisy-chaining devices. All exchanges are initiated by the host controller. The format of host communications to the FC-4 is as follows; "IFC4", address, command ( , data )
Were 'IFC4" is the preamble that allows the FC_4 to exist on the same communications line as other devices (e.g., AP-8, DC-16, etc) My concern is where it states "open true" baud modem, the serout command is PinC.1, OT2400,(xxxxx) My concern is with the OT2400 work with a Picaxe or what should I use?
My next question has to do with the Picaxe 40x2. In the basic command manual under the run command it states:
#slot 0
if pinC.1 = 1 then
run 1
if pinC.2 = 1 then
run 2
What I would like to know is there a way to use something similar using 1 button on pinC.1 to step thru each if statement and then use a second button on pinC.2 to select any given one. Hope this makes sense.
Thank you
David Warren
#slot 0
if pinC.1 = 1 then
run 1
if pinC.2 = 1 then
run 2
Thank you
David Warren
