fernando_g
I am planning to build a light chaser, on which the strings of LEDs is lit up with sequences like the following example:
0000 0000
1000 0000
0100 0000
0010 0000
0001 0000
0000 1000
0000 0100
0000 0010
0000 0001
then a new sequence follows:
1100 0000
0110 0000
0011 0000
0001 1000
0000 1100
0000 0110
0000 0011
and another;
1110 0000
0111 0000
0011 1000
0001 1100
0000 1110
0000 0111
and so on.................
What I am planning to do is to read the sequences from an external I2C EEPROM, and then simply apply them to a port. The port will of course drive the proper transistors which will handle the large current requirements.
The hardware is up and running, and a short sample sequence is running correctly. They look fantastic!
I loaded the data from the Picaxe's memory to the EEPROM for this short test sequence.
This is fine for a short sequence, but I am planning to load hundreds of bytes into the EEPROM. How to do it, from the Serial Terminal?
Or would it be a better way?
0000 0000
1000 0000
0100 0000
0010 0000
0001 0000
0000 1000
0000 0100
0000 0010
0000 0001
1100 0000
0110 0000
0011 0000
0001 1000
0000 1100
0000 0110
0000 0011
and another;
1110 0000
0111 0000
0011 1000
0001 1100
0000 1110
0000 0111
