Lego Boost. Problem with motors
tsadowski
New member
I have the same effect since the last Lego App update. Lego changed some function ports. You can see the necessary changes for pylgbst here:
So we need an update to S2Bot.
Cheers,
Torsten
laurent_c
Hello,
Could you open-source the "s2bot" code so the Picaxe Community can contribute to a quick fix to this issue.
Thank you.
Best Regards,
Laurent
laurent_c
Hello,
LEGO BOOST newest firmware changed the port number for all motors:
motor_A changed from 0x37 to 0x00
motor_B changed from 0x38 to 0x01
motor_AB changed from 0x39 to 0x10
motor_D changed from 0x02 to 0x03
Could you make this change to the "s2bot" code?
Thank you
Best Regards,
Laurent
