Learning to Drive an LCD DISPLAY
#41
Mark I got it to display correctly on a 08m2 with this code
[color=Blue]serout c.0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]1[/color][color=Blue])
pause [/color][color=Navy]2[/color]
[color=Blue]serout c.0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]128[/color][color=Blue]) [/color][color=Green]; move to start of first line[/color]
[color=Blue]pause [/color][color=Navy]2     [/color]
[color=Blue]serout c.0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Red]"88888888888888888888"[/color][color=Blue]) [/color][color=Green]; output text[/color]
[color=Blue]serout c.0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]192[/color][color=Blue]) [/color][color=Green]; move to start of first line[/color]
[color=Blue]pause [/color][color=Navy]20    [/color]
[color=Blue]serout c.0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Red]"88888888888888888885"[/color][color=Blue]) [/color][color=Green]; output text[/color]
[color=Blue]serout c.0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]148[/color][color=Blue]) [/color][color=Green]; move to start of first line[/color]
[color=Blue]serout c.0[/color][color=Black],[/color][color=Blue]n9600_8[/color][color=Black],[/color][color=Blue]([/color][color=Navy]254[/color][color=Black],[/color][color=Navy]212[/color][color=Blue]) [/color][color=Green]; move to start of first line[/color]
those are about the minimum amount of pauses required
http://youtu.be/M-27C_nIqII
in your control section can i add my own case say "$57" and have it do another set of codes
[color=Black]Commands:
   [/color][color=Blue]SERIN [/color][color=Black]Rx,[/color][color=Blue]N9600_32[/color][color=Black],sentdata
   [/color][color=Purple]pinsC [/color][color=DarkCyan]= [/color][color=Black]sentdata [/color][color=DarkCyan]/ [/color][color=Navy]16
   [/color][color=Blue]IF [/color][color=Purple]pinsc [/color][color=DarkCyan]= [/color][color=Navy]$2 [/color][color=Blue]then [/color][color=Black]Control
   [/color][color=Blue]LOW [/color][color=Black]RS
    [/color][color=Blue]PULSOUT [/color][color=Black]E,[/color][color=Navy]1 [/color][color=Black]: [/color][color=Purple]pinsC [/color][color=DarkCyan]= [/color][color=Black]sentdata : [/color][color=Blue]PULSOUT [/color][color=Black]E,[/color][color=Navy]1
   [/color][color=Blue]HIGH [/color][color=Black]RS
    [/color][color=Blue]GOTO [/color][color=Black]Main
Control:
   [/color][color=Blue]SELECT CASE [/color][color=Black]sentdata
   [/color][color=Blue]case  [/color][color=Navy]$20  [/color][color=Blue]low b.0
   case  [/color][color=Navy]$21 [/color][color=Blue]high b.0
   case  [/color][color=Navy]$22  [/color][color=Blue]low b.5
   case  [/color][color=Navy]$23 [/color][color=Blue]high b.5
   case  [/color][color=Navy]$24  [/color][color=Blue]low b.2
   case  [/color][color=Navy]$25 [/color][color=Blue]high b.2
   case  [/color][color=Navy]$26  [/color][color=Blue]low b.3
   case  [/color][color=Navy]$27 [/color][color=Blue]high b.3
   END SELECT
    GOTO [/color][color=Black]Main  [/color]
i want to be able to add a RTC to this 20m2 thats running the lcd and send a code from a 08m2 to retrieve that info
marks
#42
Hi ac21,
glad to see your've had a win.
you should be able to use $20-$70(command lcd codes we wont be needing).
It would be easier to code if the RTC were added to the 08m2
time to draw out a plan i always look at the hardware first, requiring the least ammount of easy coding lol.
Ruff examples here we could probaly improve upon.whatever control tasks we employ remember may require addition pause times to complete.
#picaxe 18m2  ' version 2.A * Testdrive 4bit/8bit Serial driver boards* marks
SETFREQ M16
                                ' when using 4bit board to send I use c.0
serout b.0,n9600_16,(254,192)   ' Command Line 2 Cursor Position
pause 2
serout b.0,n9600_16,("Marks 9600          ")
pause 45
  serout b.0,n9600_16,(254,$21) ' Control High OUTPUT 1
pause 4000
pause 2
serout b.0,n9600_16,("           123456789")
pause 45
  serout b.0,n9600_16,(254,$50) ' Control Low OUTPUT 1
pause 2000
	#picaxe 18m2    'version 2.A * 4 BIT SERIAL DRIVER 9600 baud * marks
	#terminal off
'            DB7  = C.3
'            DB6  = C.2
'            DB5  = C.1
'            DB4  = C.0
      SYMBOL Rx   = C.5
	SYMBOL E    = B.6
	SYMBOL RS   = B.7
	SYMBOL senddata    = b0	 SYMBOL sentdata    = b0
	SYMBOL index       = b1
	SYMBOL batV        = b2
	SYMBOL ADCval      = b3
      SYMBOL D1          = b4
	SYMBOL D2          = b5
	EEPROM 0 ,($03,$03,$03,$02,$02,$08,$0,$0C,$0,$01)'(4Bit)(2line/5x8)(Display On)(Clear Display)	 16  8  4  2  1
      EEPROM 10,(6 ,9 ,9 ,6 ,0 ,0 ,0 ,0) ' load custom character (o) =0                                 *  '  '  '  *  17
      EEPROM 18,(14,17,17,31,17,17,0 ,0) ' load custom character (A) =1                                 *  *  '  *  *  27
      EEPROM 26,(30,17,17,30,16,16,0 ,0) ' load custom character (P) =2                                 *  '  *  '  *  21
      EEPROM 34,(17,27,21,17,17,17,0 ,0) ' load custom character (M) =3                                 *  '  '  '  *  17
      EEPROM 42,(14,17,16,16,17,14,0 ,0) ' load custom character (C) =4                                 *  '  '  '  *  17
      EEPROM 50,(30,16,16,28,16,16,0 ,0) ' load custom character (F) =5                                 *  '  '  '  *  17
      EEPROM 58,(0 ,31,1 ,31,16,16,31,0) ' load custom character (2) =6                                 '  '  '  '  '  0
      EEPROM 66,(14,10,14,0 ,14,10,10,0) ' load custom character (on)=7                                 '  '  '  '  '  0
                                         '                                                           custom character example (M)=3
	CALIBADC10 ADCval
      SETFREQ M32
 	dirsB = %11101101
 	dirsC = %00001111
 	batV = 10475 / ADCval
      BinToAscii batV,D2,D2,D1
Initialise:
	FOR  index = 0 to 9
          READ index, senddata : pinsC = senddata : PULSOUT E,1 ' Initialise LCD
 	NEXT index : PAUSE 10
DisplaySupply:
	HIGH RS
      FOR  index = 0 TO 15
 	    LOOKUP index,("LCD Supply ",D2,".",D1,"V "),sentdata
 	                           pinsC = senddata / 16 : PULSOUT E,1 : pinsC = senddata : PULSOUT E,1 ' sending characters to line one
      NEXT index
LoadCustomCharactersFromEEPROM:
       LOW RS : senddata = $40 : pinsC = senddata / 16 : PULSOUT E,1 : pinsC = senddata : PULSOUT E,1 : HIGH RS ' Load Characters to LCD
 	FOR  index =10 TO 73
 	    READ index, senddata : pinsC = senddata / 16 : PULSOUT E,1 : pinsC = senddata : PULSOUT E,1 ' sending characters to LCD
 	NEXT index
' TestCustomCharacters:
'       LOW RS  :senddata = 192 : pinsC = senddata / 16 : PULSOUT E,1 : pinsC = senddata : PULSOUT E,1  '(192-211) Line 2 Cursor Position
'      HIGH RS
'      FOR  index = 0 TO 12
' 	    LOOKUP index,("Test ",0,1,2,3,4,5,6,7),senddata
' 	                            pinsC = senddata / 16 : PULSOUT E,1 : pinsC = senddata : PULSOUT E,1 ' sending characters to line two
'      NEXT index
Main:
    bptr=28
   SERIN Rx,N9600_32,@bptr
   IF @bptrinc = 254 THEN Commands
   SERIN [10],Rx,N9600_32,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,_
                          @bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc ' upto 20 Characters
    @bptr = 254
     bptr = 28
       do until @bptr = 254
        pinsC = @bptr / 16 : PULSOUT E,1 : pinsC = @bptrinc : PULSOUT E,1
   GOTO Main
Commands:
   SERIN Rx,N9600_32,sentdata
   pinsC = sentdata / 16
   IF pinsc = $2 then Control2x
   IF pinsc = $5 then Control5x
   LOW RS
    PULSOUT E,1 : pinsC = sentdata : PULSOUT E,1
   HIGH RS
    GOTO Main
Control2x:
   SELECT CASE sentdata
   case  $22  low b.5
   case  $23 high b.5
   case  $24  low b.2
   case  $25 high b.2
   case  $26  low b.3
   case  $27 high b.3
   case  $21 high b.0
   END SELECT
    GOTO Main
    Control5x:
   case  $52  low b.5
   case  $53 high b.5
   case  $54  low b.2
   case  $55 high b.2
   case  $56  low b.3
   case  $57 high b.3
   case  $50  low b.0
   END SELECT
    GOTO Main
marks
#43
9600 Bps or Hi2Cfast OLed/LCD firmware for the 20x2picaxe
Lately there's been some interest using 9600 Bps or Hi2C to drive a Display.
originally an 18m2 was used for sending our data to 20x2picaxe driver in post#20
but many are wanting to use the bigger chips so I'm adding some examples using the 40x2
which should also work with the 28x2 as slight code variations can sometimes be needed with different chips.
I've separated them so hopefully this will make it easier to get started!
N9600
#picaxe 20X2   '  versions C.0 C.1 C.3    *LCD/OLED driver 4Bit (9600Bps)* marks
#no_data       '    .-----_-----.
#terminal off  '    | V+     0V |
               ' -->| SI     SO |--> a.0 Control output
'       Rx N9600 -->| C.7   B.0 |--> LCD DB4
'  (10K pulldown)   | C.6   B.1 |--> LCD DB5
'                   | C.5   B.2 |--> LCD DB6
'                   | C.4   B.3 |--> LCD DB7
'         LCD E  <--| C.3   B.4 |
'         LCD RS <--| C.2   B.5 |
'                   | C.1   B.6 |
'                   | C.0   B.7 |
     	SYMBOL Rx     = C.7
	SYMBOL E      = C.3
	SYMBOL RS     = C.2
	SYMBOL senddata = b0 : SYMBOL sentdata = b0
	SYMBOL index    = b4
	TABLE   0, ($3,$3,$3,$2,$2,$8,$0,$C,$0,$1,$0,$2,$0,$6)  '(4Bit)(2line/5x8)(Display On)(Clear Display)(Return Home)(Entry Mode Set)
	TABLE  40, ("marks......")
	SETFREQ M64
 	dirsB = %00001111
 	dirsC = %10111111
IntialiseDisplay:
      FOR  index = 0 to 13
READTABLE index, senddata : outpinsB = senddata : PULSOUT E,1 ' Initialise LCD/OLED
Display:
      LOW RS
      senddata = 128 : outpinsB = senddata >> 4 : PULSOUT E,1 : outpinsB = senddata : PULSOUT E,1'(128-147) Line 1 Cursor Position
      HIGH RS
      FOR index = 40 TO 50
 	   outpinsB = senddata >> 4 : PULSOUT E,1 : outpinsB = senddata : PULSOUT E,1 ' sending characters to line one
 	   pause 500
 	NEXT index
 Main:
  SERIN Rx,N9600_64,sentdata
   IF sentdata = 254 THEN Commands
   outpinsB = sentdata >> 4 : PULSOUT E,1 : outpinsB = sentdata : PULSOUT E,1
   GOTO main
 Commands:
    IF outpinsB = $2 then Control
    LOW RS : PULSOUT E,1 : outpinsB = sentdata : PULSOUT E,1 : HIGH RS
    GOTO Main
 Control:
    case  $20  low a.0
    case  $21 high a.0
    END SELECT
    GOTO Main
#picaxe 40x2  ' version B.3 * Testdrive  4bit/20x2 9600 driver * marks
#no_data
SETFREQ M16
PAUSE 1400
Main:
BinToAscii W1,b8,b7,b6,b5,b4
INC W1
serout c.0,n9600_16,(254,192)   ' Command Line 2 Cursor Position
serout c.0,n9600_16,("* *  9600 ",b8,b7,b6,b5,b4)
serout c.0,n9600_16,(254,$21) ' Control A0 high
pause 2000
serout c.0,n9600_16,(" * * 9600 ",b8,b7,b6,b5,b4)
serout c.0,n9600_16,(254,$20) ' Control A0 low
pause 2000
Hi2Cfast
#picaxe 20X2   '  versions C.0 C.1 C.3     *LCD/OLED driver 4Bit (Hi2C fast)* marks
'              ' -->| SI     SO |--> a.0 Control output
'                   | C.7   B.0 |--> LCD DB4
'                   | C.6   B.1 |--> LCD DB5
'         LCD RS <--| C.2   B.5 |--> SDA Hi2C (2.2k pullup)
'                   | C.1   B.6 |
'                   | C.0   B.7 |--> SCK Hi2C (2.2k pullup)
	SYMBOL E      = C.3
	SYMBOL RS     = C.2
	SYMBOL index    = b4
	SETFREQ M64
 	dirsB = %00001111
 	dirsC = %10111111
IntialiseDisplay:
      FOR  index = 0 to 13
 Display:
       LOW RS
       HIGH RS
  	   pause 500
       NEXT index
HI2CSETUP I2CSLAVE, %10100000
 Hi2C:
  ptr = 0
  hi2cflag = 0
  SETINTFLAGS %01000000 , %01000000
   Main:
    IF hi2cflag = 0 THEN main
Interrupt:
 ptr = 0
 IF @ptrinc = 254 THEN CommandsHi2c
 FOR  ptr = 0 TO hi2clast
 outpinsB = @ptr >> 4  PULSOUT E,1 : outpinsB = @ptr  PULSOUT E,1
 NEXT ptr
 GOTO Hi2C
 CommandsHi2c:
 IF outpinsB = $2 THEN ControlHi2c
 LOW RS : PULSOUT E,1 : outpinsB = @ptr : PULSOUT E,1 : HIGH RS
 GOTO Hi2C
 ControlHi2c:
    SELECT CASE @ptr
    case  $20  low a.0
    case  $21 high a.0
    END SELECT
    GOTO Hi2C
#picaxe 40x2  ' version B.3 * Testdrive  4bit/20x2 Hi2C driver * marks
#no_data
#no_table
SETFREQ M16
HI2CSETUP I2CMASTER,%10100000,I2Cfast_16,I2Cbyte
PAUSE 1400
Main:
INC W1
HI2COUT 0,(254,192) ' Command Line 2 Cursor Position
pause 10
HI2COUT 0,("*    Hi2C ",b8,b7,b6,b5,b4)
pause 40
HI2COUT 0,(254,$21) ' Control A0 high
pause 2000
HI2COUT 0,(254,192)
pause 10
HI2COUT 0,(" *   Hi2C ",b8,b7,b6,b5,b4)
pause 40
HI2COUT 0,(254,$20) ' Control A0 low
pause 2000
pause 10
pause 40
pause 2000
HI2COUT 0,(254,192)
pause 10
pause 40
pause 2000
marks
#44
Hser OLed/LCD firmware for the 20x2picaxe
The sending code was checked on an LCD it appears Oleds can have more characters per line controller (64) not 40 as assumed
so will appear different than intended will change it when I get around to it. so cut to 40 as I don't have a oled2004 at the moment.
The picaxe 20x2 @ 64mhz can easily keep up while receiving N9600_16
we can send all 80 characters in one go and most pins can be used.
'#picaxe 40x2  ' version B.3 * Testdrive  4bit/20x2 N9600 driver
 #picaxe 18m2  ' version 2.D
#no_data
low c.1                        ' sometimes required to prevent corruption of first serout bytes
SETFREQ M16                     ' or M8 for N9600_8 can be used
PAUSE 3000                      ' allow some time for driver to complete
Main:
serout c.1,n9600_16,(254,128)   ' Command Line 1 Cursor Position (128-147)
serout c.1,n9600_16,("1111111111222222222233333333334444444444") '5555555555666666666677777777778888888888")
 pause 8000                     ' no pauses required after sending any characters just used so you can see the change
 serout c.1,n9600_16,(254,$20) ' Control A0 low
 pause 10
serout c.1,n9600_16,(254,1)     ' Clear All
pause 1                        ' sometimes required for clear and home to stop missing characters in next line
                                ' if other commands for outputs or messages are created you will need to work the pause required after it.
serout c.1,n9600_16,("marks")
 pause 2000                      ' no pauses required after sending any characters just used so you can see the change
 serout c.1,n9600_16,(254,$21) ' Control A0 high
 pause 10
serout c.1,n9600_16,("        ")
 pause 4000                     ' no pauses required after sending any characters just used so you can see the change
GOTO main
For each character we are sending 10 bits
(start ,bit0,bit1,bit2,bit3,bit4,bit5,bit6,bit7, stop) also called a frame or packet.
Usually the time of the stop bit and until we start again, is where we can do our stuff.
When the frequency of the sending picaxe is increased N9600_32 our receiving picaxe has less time to update the display and we may see some mixed results.
If we need a faster baud we can look at using hardware serial. B9600 up to B115200 (but will need to use the dedicated pins.)
HserOut
 '#picaxe 40x2  ' version B.3 * Testdrive  4bit/20x2  Hserout C.6
 #picaxe 18m2   ' version 2.D  Hserout B.5
#no_data
SETFREQ M16
PAUSE 1400
HSERSETUP B115200_16, %00010  ' ( normal serial )
Main:
hserout 0,(254,128)   ' Command Line 1 Cursor Position (128-147)
 pause 5              ' 19200  38400  57600  115200 not required for 9600
 pause 2              ' required for 18m2
hserout 0,("1111111111222222222233333333334444444444") '5555555555666666666677777777778888888888")
 hserout 0,(254,$20) ' Control A0 low
 pause 10
hserout 0,(254,1)     ' Clear All
hserout 0,("marks")
 hserout 0,(254,$21) ' Control A0 high
 pause 10
hserout 0,("        ")
 pause 4000
GOTO main
Hser
#picaxe 20X2   '  version C.3     *LCD/OLED driver 4Bit (Hser)* marks
'                   | C.1   B.6 |<-- HserIN  (10K pulldown)
'        HserOUT <--| C.0   B.7 |
	SYMBOL E      = C.3
	SYMBOL RS     = C.2
	SYMBOL index    = b4
	SETFREQ M64
 	dirsB = %00001111
 	dirsC = %10111111
IntialiseDisplay:
      FOR  index = 0 to 13
 Display:
       LOW RS
       HIGH RS
  	   pause 500
       NEXT index
HSERSETUP B115200_64, %00101  ' ( normal serial in , scratchpad ) 9600  19200  38400  57600  115200
Hser:
  hserptr = 0
  hserinflag = 0
   Main:
    IF hserinflag = 0 THEN main
   ptr = 0 pause 10
  IF @ptrinc = 254 THEN CommandsHser
     ptr =0 pause 50
     do while ptr < hserptr
       outpinsB = @ptr >> 4  PULSOUT E,1 : outpinsB = @ptrinc  PULSOUT E,1
   GOTO Hser
 CommandsHser:
 IF outpinsB = $2 THEN ControlHser
 GOTO Hser
 ControlHser:
    SELECT CASE @ptr
    case  $20  low a.0
    case  $21 high a.0
    END SELECT
    GOTO Hser
