LCD simulation opened when simulating sertxd-message block
#2
The LCD simulation panel when enabled opens whenever there is a SERTXD or SEROUT command in the program, regardless of which pin that simulated LCD is connected to. This is the case for Basic, Flowchart and Blockly simulation.
It is effectively 'turning on the LCD when the PICAXE is turned on' as simulation starts. To disable the LCD simply select it not to be simulated.
#5
There is no directive I know of at present but I would guess it could perhaps be added. Whether it would be is another question but I will log the suggestion for the development team.
