LCD Serial Display
jc173
I've got a PCB, soldered on 3 flying wires going to the Serial LCD and used the following BASIC syntax as a test
          serout 7, N2400, ("Test 1 2 3")
When everything is switched on it is not working at all.
I have run test codes to check the other in/output devices work and they all do, i've replaced the screen with another screen....
any ideas?
TIA
James
James,
try adding an extra line
PAUSE 500​
at the start before the SEROUT command.
Can try longer than 500 if you want
That will give the display time to initialise.
Next step would be to send a reset command to the LCD (read the LCD manual to find out how to do that)
Just to make sure you are on the right track:
which PICAXE chip are you using?
Which physical pin is the LCD connected to?
jc173
If you get nothing at all on the screen don't forget the contrast adjustment!
Thanks for that, have been playing with that to ensure it's right
James,
PAUSE 500​
ok, pause 500 will try that :)
Micro controller is a PICAXE 18A
it's on physical pin 13 which is I/Put 7 :)
eclectic
@James.
I don't have an 18A, so I used an 18X
AXE091 board / AXE033 LCD
Power = 4 x NiMh AA ~ 4.97v
The following four programs all work, producing screen output.
  serout 7, N2400, ("Test 1 2 3 *")
serout 7,n2400,(254,1)
pause 50
I then changed power supply to three slightly used AA (~ 4.4v)
= NO display.
Please check your PCB wiring and your power supply.
The AXE033 needs ~ 5.0 v.
e
jc173
@James.
pause 50
= NO display.
e
Power Supply is a 6.0v AC --> Adaptor
eclectic
"The device is mains operated so it uses a plug in 6.0V transformer to convert back from 230v AC to 6.0v DC output"
6 VOLTs? For the Picaxe and the LCD?
Oh Dear..........
e
jc173
Oh.
e
Yes 6v supply for the whole circuit...basically a 4 cell battery pack effect....
eclectic
"Yes 6v supply for the whole circuit...basically a 4 cell battery pack effect...."
What IS your power supply?
Unregulated / regulated/ ...........
6 volts sounds extreme for an LCD display. :-(
e
jc173
e
It's a AC Plug in Power Supply Unit (Output 6v), unsure if it's regulated or unregulated...i'd guess at unregulated
In which case, unloaded (or with just a PICAXE and LCD) it likely to be close to 9v. Enough to destroy both PICAXE and LCD.
STRONGLY suggest the use of batteries or a quality REGULATED 5v supply.
@James.
e
The AXE033 has a link that can be fitted to permit operation for a 4.5V supply (eg 3 x AA batteries). I use a header and bridge link than can be removed or fitted as necessary.
Unfortunately many Rev Ed datasheets DO reference 6Vdc as the supply.
jc173
I think i've found my problem, We currenty have 3 pins connected:
V+
V-
and on output pin 7 (Physical 13)
Is there a requirement to have an input pin connected two, meaning 4 pins??
No input pin required. Are you connecting to output 7 directly (correct) or to the darlington driver output on a project board like the CHI030 (incorrect) ?
boriz
"it is just under 6 volts, at about 5.7"
Assuming that’s a DC reading on a DC transformer...
If that's the unloaded reading for an unregulated 6v transformer then throw it away, it's probably broke.
If that's the reading for a regulated 6v transformer, then it's fairly close to spec, and if it stays close to the same level when loaded, then it's probably working fine. But throw it away anyway because it's useless for a Picaxe. (Or you can use a series silicon rectifier diode to drop .7v but that’s really just a botch solution and not good practice for a finished project)
Use an unregulated 9v transformer and a 7805 5v regulator. I think that’s what most people do. Should work fine if you haven’t already fried something.
jc173
Directly connecting and then using a 3 pin connector onto the Pin on the LCD :)
JC173,
exactly which serial LCD module are you using? :confused:
If it is the AXE033 you would have to have assembled it.
Many here are assuming the AXE033 but is it from another vendor (eg Peter Anderson)?
which board do you have the PICAXE chip on? a Rev Ed protoboard or breadboard.
Can you upload a photo of your arranagement - clear enoght so that we can see each wire and a circuit schematic diagram (or sketch) would be helpful.
jc173
JC173,
AXE033 is what I'm using
It's a PCB etched at school.
Can't get a photo but, i do have a schematic diagram of the PCB attached
