Andrew Cowan
I am using a 28X PIC and the Picaxe LCD/Clock display connected to output 7.
The PIC works fine, and will even play a tune when a piezo is connected to output 7.
There is power going to the display, and continuity between the input pin and output 7 on the PIC.
I did have it working, then I took the circuit to school and it got a bit crushed. It is on a breadboard. When I say crushed, I don't mean smashed - there is no damage apart from a few of the wires on the breadboard getting knocked.
If there is power and signal going to the display, what could be wrong?
I have tried it with two displays, and I have used both the sample program, and the one I wrote that worked before. Any ideas?
Andrew
Andrew
