lcd display not showing
animal2
I have attached an LCD 16X2 Display in Parallel 4 Bit mode
Sim works fine , BUT the LCD wont display anything
All connections are fine.
I have an actual working circuit, so I know it works
Any Help
Vaiable Data Also Wrong
In the Programming Editor , the Simulator shows the correct values for the variables(bo,b1,etc)
In VSM The variables are the wrong values eg "B0"
b0 and B0 are the same thing, either is acceptable.
The issue with your program is a bug in the beta version, the lookup command is not working as expected. We will look into this.
This modification of your program without lookup works
symbol latchout=1
symbol lcddata=1
symbol lcdinst=0
symbol outbyte=b0
symbol rs=b1
symbol counter=b2
symbol nblcount=b3
rs=lcdinst
'for counter=0 to 5
'lookup counter, ($33,$32,$28,$0C,$01,$06), outbyte
'gosub lcdout
'next counter
outbyte = $33
gosub lcdout
outbyte = $32
gosub lcdout
outbyte = $28
gosub lcdout
outbyte = $0C
gosub lcdout
outbyte = $01
gosub lcdout
outbyte = $06
gosub lcdout
loop1:
rs=lcdinst
outbyte=$80
gosub lcdout
rs=lcddata
'for counter=0 to 4
'lookup counter, ("Hello"),outbyte
'gosub lcdout
'next counter
outbyte = "H"
gosub lcdout
outbyte = "e"
gosub lcdout
outbyte = "l"
gosub lcdout
outbyte = "l"
gosub lcdout
outbyte = "o"
gosub lcdout
goto loop1
lcdout:
for nblcount=1 to 2
pins=outbyte&$F0| 2| rs
low latchout
outbyte=outbyte*16
next  nblcount
Back
