Brooklyn187m
Hello,
I am brand new to microcontrollers and a somewhat novice to electronics in general. I picked up the AXE090 kit with a PICAXE 18X chip. My goal thus far is to interface the 18X with either one of my parallel LCD screens that I picked up on the cheap. Just getting it to work is it, nothing special.
The 16x2 LCD is a Powertip LCD PC1602-F
The 24x2 LCD is a EDT EW24210BFW
I have the LCD connected exactly the way it describes on the boards and other places. Both LCDs use HD44780 compatible controllers and have identical pinouts.
When I upload the code to the picaxe, nothing happens on the powertip. It just displays black boxes. The EDT shows garbage characters and sometimes scrolls them.
I think my problem is that I am not getting the initialization codes right. I am not sure how to modify the code to use either one of my LCDs. I have tried sample code from here and other places. I would appreciate any help offered. Thanks!
Here is the code without the main writing loop.
' **** Constant Definitions ****
symbol En = 3 ' LCD Enable pin connected to PICAXE output 3
symbol RS = 2 ' LCD RegSel pin connected to PICAXE output 2
' **** Variable Definitions ****
symbol char = b1 ' character to be sent to LCD
symbol index = b2 ' used as counter in For-Next loops
' **** Subroutine init ****
init: pins = 0 ' clear all PICAXE output lines
pause 200 ' pause 200 mS for LCD initialization
pins = 48 ' instruction: set to 8-bit operation
pulsout En,1 ' send data to LCD
pulsout En,1 ' send data (necessary)
pins = 32 ' instruction: set to 4-bit operation
pulsout En,1 ' send again (necessary in 4-bit mode)
pins = 128 ' instruction: set to 2 line operation
char = 14 ' instruction: screen on, cursor on
gosub wrins ' send instruction to LCD
char = 1 ' instruction: clear display, cursor home
char = 12 ' instruction: hide cursor
' **** Subroutine wrchr ****
wrchr: pins = char & 240 ' place high nibble of char onto pins
high RS ' make sure RS is high
pins = char * 16 ' place low nibble of char onto pins
' **** Subroutine wrins ****
wrins: pins = char & 240 ' place high nibble of char onto pins
