How do i check if i have blown my H-bridge motor driver?
I have verified with my multimeter that the inputs are sending the right voltages from my uln darlington IC.
All connections are correct, just no motor movement, from a simple "let pins = %10000000"
motor specs are
.5A @ 12v
Driver is using a separate 12v power supply
Darlington IC and Picaxe 28x1 are using same 5v power supply
all are connected to a common ground.
motor specs are
.5A @ 12v
