Pauldesign
Hi
I don't know if it's Proteus or PICAXE or me.
1)Why does a VSM file corrupts if rename or save with a different file name or on a different directory (drive), which in order to fix it, the .bas file has to be re-downloaded unto the the picaxe(s) in the circuit.
2) Some parts e.g the Schmidt trigger NAND gates model HCT132 doesn't simulates. gives errors. I guess spice model was made wrongly.
3) Data viewed using Virtual terminal instrument gets corrupts if baud rate is change even to a lower value. Change to higher values makes sense.
4) Data (numbers) disappears on Virtual terminal if multi-instruments (scope) are connected to the same signal.
Rgds
Paul
Rgds
Paul
