Hi Everyone
I am a total noob to electonics and am still strugaling with some of the termanology you guys use. I have tried to read the picaxe manuals to see if a picaxe chip will do what i want before i buy one of your sets but i am still non the wiser so any help or advice will be much appreciated.
I want a chip that on a momantary pulse from a micro switch will turn 1 of the chip out puts on and then on a second touch will turn it off.
Then a momantary pulse from a micro switch to another input starts a sequence of outputs across 9 output pins that will continue until the same input pin recives another pulse
Then if a third input is high the previously mentioned 9 output pins all go high overiding the sequence.
Then a forth and fith input pin that on a momantary pulse from a micro switch will turn on yet another of the chip outputs and make it flash and then on a second touch will turn it off.
Does this sound possible. and how complicated would the code be to make it happen. I have had a play about with the flow chart software but not had much luck yet. Am i being over ambisious?
Any help much appreciated
Thanks.
Joe.
Thanks.
Joe.
