Is there a Picaxe with a reasonable resolution DAC ?
erco
AFAIK it's only 5 bit resolution (32 equal steps) and I just noticed that on the M2 series, only the 18M2 has a DAC output which is NOT the serial output pin.
Reloadron
Just about any PICAXE will give 8 bit resolution and there is always the:
Name:
readadc10
Syntax:
READADC10 channel,wordvariable
So just about any PICAXE will give you 8 bit and using the above will get you 10 bit on some chips. What did you have in mind?
Ron
rq3
By reasonable, I mean at least 8bits...
I think I'll have to resort to an external DAC, but just to be sure.
A PWM output into a simple low pass filter will give you 10 bits, if the load current is small enough.
Can you provide more details? What's the DAC output ultimately going to do?
Rip
Reloadron
Many thanks for pointing out the error of my ways. I refuse to believe I clearly read "DAC" as ADC, however, I obviously did manage to do that. I have not even had a hard cider yet this evening. May as well start now and just think, for over 40 years I managed to earn a living in electronics, now I have doubts about spelling it correctly. :)
Thanks Guys
Ron
