Irin command in Logicator (PE6)
#1
Is there any way to specify the address to go to when using the timeout parameter? (i.e. the equivalent of "IRIN [timeout, address], pin, variable"). I see that there is a checkbox which generates the equivalent of "IRIN [timeout], pin, variable" but I don't see any way of specifying an address to go to on timeout.
I want to use the command to control robot motors and turn off the motors if no key on an IR TV remote is pressed.
nick12ab
#2
Use a BASIC cell for the irin command that you want to specify the address for, and create an additional BASIC cell (elsewhere in your flowsheet immediately before the command you want to jump to) containing the label you have specified as the address.
