IRIN Command Hangs Up
4jaba6
I am using a 20M2.
The IRIN command works well for a few times.
The program cycles and visits the IRIN each time it recycles.
Anywhere from the 2nd to 4th or 5th program circuit, IRIN hangs up and does not leave.
Apparently it does not "timeout" !???
Is it possible that the time(timeout) being monitored would somehow get greater than the timeout specified and
consequently the command not know what to do?
Explanations and esp. SOLUTIONS will be greatly appreciated.
TIA ( Thanks in Advance )
John
eclectic
I am using a 20M2.
John
First off John,
Program and Circuit please.
e
4jaba6
PROGRAM:
irin[7000,SEARCHDONE],C.4,reccode
if reccode = 59 then GOTO TRANSLOOPB
pause 100
GOTO SEARCHDONE
CIRCUIT:
The circuit is the basic circuit for an IR receiver sensor...
such as a Panasonic 4602 or TSOP 38238.
They have 3 pins.
As one faces the Sensor:
+5V is on right
ground is in middle
20M2 pin is on left
AllyCat
You haven't given enough code for us to be able to judge if there might be any "bugs", but the way to solve problems like this is to use the "Debugging" features of the Program Editor / Terminal Emulator. Add SERTXD commands to indicate each stage of the program execution to see where (and maybe why) it hangs, for example:
#picaxe 20m2
#terminal 4800     ; Assuming a normal SetFreq M4
sertxd (cr,lf,"Waiting for IR")
TRANSLOOPB:
sertxd (cr,lf,"TransLoop Entered, value= ",#reccode)
SEARCHDONE:
sertxd (cr,lf,"SearchDone Entered")
; etc..
Isn't a better description of "SearchDone" actually "SearchFailed" ?
Hi John,
(Beaten to the punch by Alan. But anyway, my code does almost exactly the same thing, altough it is a complete hardware diagnostic.)
Try the following code. It will show if there are any hardware issues.
Peter
Rich (BB code):
#picaxe 20M2
#terminal 4800
SerTxd ("Bootup...", CR, LF)
Main:
      Do
         IRIN [7000,TimeOut],C.4,b0
         SerTxd (#b0, CR, LF)
      Loop
TimeOut:
      SerTxd ("Time out", CR, LF)
      Goto Main
4jaba6
Hi John,
Peter
Rich (BB code):
#picaxe 20M2
#terminal 4800
Main:
      Do
      Loop
TimeOut:
      Goto Main
ter,
Peter,
Great to hear from you again.
Peter and Alan, I appreciate your diagnostic recommendations.
I hope to test them with my project this weekend but there is a potential monkey in wood pile with Tropical Storm Fred bearing down on Florida;
so might have to delay.
I recently discovered that testing on the bench with not running the motors, the IRIN does NOT fail.
I have not tested this enough yet.
New testing shall include motors running and not running to confirm.
Eventually shall do more "floor" testing,
but difficult to do because of the download cable.
Thanks again for the Terminal diagnostic testing suggestions; I have never done this before.
John
4jaba6
I have determined that ( A ) IRIN does NOT HANGUP when on the bench with motors NOT running
and same for ( B ) with motors running and no friction floor or plat surface .
However ( C ) when on the floor, that is not the case. The IRIN command will eventually hang up
as it cycles thru the program several times. I started to believe that the issue might be somehow related to friction of floor.
I took Inglewoodpete and Alan's Terminal Programs and repeated the testing as above.
I had to enter motor code to their programs to do this ( see code below ).
Ran the motors on bench and not fail.
I gave the motors a chance to run on a flat surface and the "timeout's" continued to occur as they should.
My thought was that due to friction of wheels( motors ) on floor or flat surface and not freewheeling on bench
may be generating some kind of EMF event that affected the IRIN timeout ( seems kind of like an obscure reason but why would it not hang up when freewheeling but fail when running on floor ?!?! ).
The fact that timeout's seemed normal in the modified Terminal Program does not appear to gel with that theory.
Next is the modified program.
Perhaps there is better code to address solving this problem than the motor code I used.!?!?
#picaxe 20M2
#terminal 4800
Main:
HIGH B.6
PAUSE 500 'Motor Code to go forward in short spurts
LOW B.6
HIGH C.1
LOW C.0
HIGH B.2
LOW B.3
PAUSE 250
LOW B.6
LOW C.0
LOW C.1
LOW B.2
LOW B.3
PAUSE 1000
Do
Loop
TimeOut:
Goto Main
Looking forward to suggestions/recommendations.
John
A loaded motor will produce far more electrical noise than a freewheeling motor. When you have unwanted noise on the power rail this can cause the sensor to output random pulses - and hence the timeout never occurs.
Make sure:
1) You have an external pull up resistor on the sensor output (4k7), the sensor internal pullups are normally quite high values.
2) capacitors physically close to the sensor across the power rails, both 100nF and a 47uF/100uF
3) the motors have suppressing capacitors across their contacts
4) you have well laid out power rails, keeping the motor power away from the picaxe electronics
4jaba6
Make sure:
Technical,
I appreciate your instructions on how to REDUCE MOTOR NOISE.
I Am having some difficulty visualizing schematics but I believe have
found some help in Picaxe books.
Regarding Your Comments:
1) Book: "Programming and Customizing the Picaxe Microcontroller has an infra-red receiver sensor circuit on page 61. It uses the 4K7 resistor you recommend. They show the resistor between picaxe pin/sensor output and + 5v. I always thought the resistor went directly between the sensor output and the picaxe pin!?!? ( see attachment A )
2) Book: "Picaxe Microcontroller Projects for the Evil Genius" page 219 shows the 47/100 uf
capacitors across the power rails. I assume this is motor power rails ( microcontroller? both? ).
I am using an L293D for "motor control". ( see attachment B )
I can not figure out where to place the 100nf capacitor you recommend?
3) I have a motor supply diagram that shows .01uF capacitors between motor supply on the L293D and ground.
( also see attachment B )
4) The motor power is away from the electronics.
I scanned the attachments but in the "preview" to this post,
it appeared that they would not attach.
From what I can tell, they are in PDF format.
Is there a better way of attaching?
Is there a tutorial showing how to use a keyboard to draw the kind of schematics/circuits we are discussing?
Thanks,
John
1) ... It uses the 4K7 resistor you recommend. They show the resistor between picaxe pin/sensor output and + 5v. I always thought the resistor went directly between the sensor output and the picaxe pin!?!? ( see attachment A )
John
@John,
I'll jump in while Technical is asleep ;) .
1. Relatively low value of the pullup resistor places a lower resistance "pull up" urge on the data line between the sensor and the PICAXE input. Treat the resistor like a spring. Technical mentions that the internal pullup resistor in the IR sensor is quite weak (Ie high resistance) - equivalent to a weak spring and susceptible to external electrical noise interfering with the output. The stronger pull-up makes the circuit less suseptable to noise interference.
2. You should have two wires connecting the L293D to each motor. Solder the 100nF capacitor to the two terminals of the motor. A capacitor has a low impedance to higher frequencies, so will will remove a lot of the motor's comutator noise off the supply wires. Refer to the drawing in Manual 3 "Output Devices 5 - DC "Toy" motors (Page 12 in my copy)
3. The 10nF capacitors across the L293D's power pins adds to the noise quenching, further reducing the external effects of electrical noise.
4. It is good to keep the motor power wiring as seperate as possible from the controler (PICAXE) power wires. If the motor/s and PICAXE share a power source, the wiring for the controller should run between the controller and the power source. I think I provided a diagram some time is the past, included here again.
24787
Peter
4jaba6
@John,
Peter
Peter,
Thank You for the information and suggestions.
I am still struggling on how to attach my circuit drawings, so my comments shall probably not be in depth until I can attach the drawings.
Regarding the capacitors in items 2. and 3 from your message.
I assume polarity does not matter in item 2 for the capacitors across the motor terminals.
Polarity probably does matter for the capacitors across the power pins in item 3.
This may be a little preliminary until I can get the schematic attached.
item 3. "....... across the L293D's power pins....".
My circuit has two +5v power sources to the L293D:
A. One is from the 20M2 +5v power rail to pin 16 ( and intersection with a 10k resistor and on to enable pins 9 and 1 ).
B. The other is a Separate +7.5v ( not 5 ) power source to pin 8.
Are you wanting the.01uf capacitors across both these power sources or just one of them?
( by "across" I assume the capacitor is placed between the power source and ground )
Item 4:
Yes, You did provide the diagram previously.
I believe it was 9/13/2020 or very close to that date.
The topic was "5v Source for SN754410 Enable Pins".
THANKS AGAIN!
I did use your diagram to construct my L293D circuit and the tie-in to the 20M2.
Best,
John
Goeytex
To attach a file simply click on "Attach Files" at the bottom of the text input window. In the popup find the file on your PC, then select it and click on "OPEN". It will be attached.
If you drew the diagram by hand you will need scan into your PC or take a photo and then transfer it to your PC.
Alternatively you can redraw the diagram with Windows Paint or with a schematic capture program of some kind.
I did this one using LTSpice, saved it, and then marked it up with Paint.
4jaba6
Goeytex,
Thank you for the advice.
Apologize for the delay in getting back to you.
John
erco
Using alkaline cells? Try new batteries, their voltage is dropping under load and resetting your Picaxe. Or use separate batteries for your Picaxe and motor.
Rechargeables are much better for delivering current and maintaining voltage.
If motor noise is the culprit, try 3 filter caps per motor in a delta arrangement. 0.1 uF (104) caps are typical for small DC motors, per https://www.etechnog.com/2019/06/capacitor-with-dc-motor.html
