In past I used a Parallax BS2 for "Infrared Object Detection".
I would like to convert and use PICAXE for this detection.
Below is a clip of code:
loop:
pause 50
freqout 14, 1, 38500
irdet = in7
ir irdet = 0 then quit
goto loop
quit
( do something if obstacle detected )
The hardware consisted of an Infrared transmitter connected to pin 14 and
Infrared Receiver Sensor ( Panasonic 4602 ) connected to pin 7.
I have been searching good part of day thru "Forum" without much success.
The best I can find is:
However, this seems much more complicated hardware and software in comparison
to the BS2 solution.
Will appreciate any advice, rec.'s, links ect. for proximity detection with Infrared.
TIA
loop:
pause 50
irdet = in7
goto loop
quit
Pulsed IR Sensor
www.trainelectronics.com
TIA
