I have been trying to figure out how I could write code to cause an interrupt when parallel processing on a 20M2? Would like to use irin going low with a TV clicker. Any hints to help me??
thank you JimS
Found the answer in FORUM search. Using the new command "pause_int" within the interrupt routine takes care of my problem. Sure would be helpful if this command were documented in Mnaual 2. JimS
