When I try to run my source code on VSM, I receive the above error message.
When, instead, I step through in Debug mode, a 'goto' instruction ends up in 'nowhere territory', meaning that the program window goes gray and reads 'No source line at PC address (PC=01CE)'.
I am using a 14M processor, and the Simulation Error Log says 'PICAXE-14M VSM Model 0.0.4 (c).....'. Does this mean I am running the latest VSM version?
I have tried to change the labels involved, but the result remains the same.
However, the program runs visibly well through all sub routines using the Simulator in the Programming Editor. I have also downloaded and (hopefully installed) the official VSM version - but it makes no difference.
I wonder if someone can point me in the right direction?
Thanks and kind regards Klaus
