So I'm attempting to use a ps/2 keyboard wired directly into a 28X1 chip for a project I'm working on. There are 10k-ohm pull-up resistors on the data and clock lines, and all of the connections appear solid (I measured them with an ohm-meter). It is powered either off of a 5V bench supply or 3xAAA batteries. The keyboard seems to randomly "freeze up" though, where it will work for the first 5-10 keystrokes, then apparently stop transmitting data (checked on an oscilloscope). Sometimes it will start up again and work for another 5-10 keystrokes, but it usually seems to eventually freeze up for good. I changed the keyboard for one from a project where it had been wired into an 18X (and working fine last time i had checked), and even with this new keyboard I'm seeing the exact same behavior.
This is the code running on the 28x1 (another 28x1 can read/write to the first "status" byte to reset it so it can accept another character)
Does anyone have any suggestions for what might be causing this behavior?
startup:
put 0,0
hi2csetup i2cslave,%11100000
kbin [400,kbtimeout],b0 'grab one character
get 0,b1
if b1=1 then main 'if status=ready, discard character
put 1,b0 'if status <> ready, store character
put 0,1 'update status=ready
pause 400
kbtimeout:
