I have run the BAS805.exe with the /a command and have successfully been given an .msi file on my network. The problem is that when i try and deploy the software over my network, the software does not install on the client PCs. I believe this is because it needs a transform (.mst) file that I need to attach to the .msi file to tell the client PCs the necessary information.
Has anyone had this problem and if so can they let me know how I can create or get an .mst file to use.
The msi file works fine if i manually install it, but obviously I have to enter the relevant user information and install directory which is where my problem lies
