input voltage query
tarantulataramasalata
I am using a picaxe 08/M powered by 6v, as per instructions in the datasheets. Is it ok to activate an input using 9v, configured with a 1k protection resistor an a 10k pull down, as per the datasheet?
It's no longer recommended to power an 08 or 08M from anything more than 5.5V.
According to one Microchip datasheet I have, the maximum current injection to any I/O pin should not exceed +/-500uA ...
ww1.microchip.com/downloads/en/AppNotes/00521c.pdf
Based on the 22K used for +/-12V serial, for a 9V signal, something around 18K would seem to be the right value, and of course you can go higher, maybe even 100K.
Edited by - hippy on 17/06/2006 17:12:17
quote 'Based on the 22K used for +/-12V serial, for a 9V signal, something around 18K would seem to be the right value, and of course you can go higher, maybe even 100K.'
thanks hippy. could you explain what this bit is for - a potential divider praps? to reduce the supply from 6v to 5.5v, or to limit the current to the input from 9v?
thanks
Current limiting, as per the download circuit, rather than a divider. So the 18K goes from '9V' to PICAXE I/O, 10K pull-down from '9V' to 0V.
