Picaxe 28X2. I am having a problem with switch inputs. The code for one input which works correctly is if pinB.3 = 0 then blay blay endif. The code for the input that does not work is if pinB.6 = 0 then blay blay endif. Both pins are defined as inputs. if I place the mouse over pinB.3 a box appears saying pinB.3=1=$01=%00000001. if the mouse is placed over pinB.6 the box shows pinB.6=0=$0=%00000000. If I simulate the code the pinB.6 software executes correctly, in real life the input is recognized because other things that were working no longer work, but the code for pinB.6 is not executed.
