Innovate LC-1 wideband o2 controller bar graph display.
7cory7
I use an Innovate LC-1 wideband o2 sensor controller to monitor the Air Fuel Ratio on my Honda Accord F22A6 Turbocharged engine.
Innovate sells a guage for almost $200.00 which gives a numerical display of your Air Fuel Ratio(AFR).
As I have done most of the work on my car, I wanted a custom solution for the gauge also.
The design is a 18M2 which reads an auxiliary output from the LC-1, which can be configured to output any voltages 0-5v according to AFR, and displays the information graphically.
I use a readadc to read the 0-3.48v signal that I programmed the LC-1 to put out. The Voltage corresponds to an AFR. For very low AFR(Cylinder wash) I display only one or two leds and both the red and green sections are driven giving me an orange color. Safe AFR's are shown in green and once the AFR is in a region where detonation (PING) can occur under boost the display turns red.
It took some time to calibrate the display, but I have tried it on 2 different LC-1 controllers and it works great.
http://www.innovatemotorsports.com/products/lc1.php
The led bargraph was a fleabay job which will display red green or orange if both red and green are driven. Any bargraph will work, i just liked the tri-color option.
This project maxes out the pins available on the 18M2, but hardly touches the capabilities of the chip. A smarter person could probably have built it with and 08, but i don't have much Picaxe experience.
nick12ab
Just going to show your code here so that the code does not have to be downloaded to view it...
#picaxe 18m2
#no_data
Main:
debug
goto out
goto AFR
goto lights
Out:
high b.0
high b.1
high b.2
high b.3
high b.4
high b.5
high b.6
high b.7
high c.6
high c.7
low c.0
low c.2
AFR:
readadc C.1,b1
Lights:
if b1 >= 180 then
goto twentytwo
if b1 >= 167 then
goto twentyone
if b1 >= 154 then
goto twenty
if b1 >= 152 then
goto nineteeneight
if b1 >= 141 then
goto nineteen
if b1 >= 129 then
goto eighteen
if b1 >= 117 then
goto seventeen
if b1 >= 106 then
goto sixteen
if b1 >= 93 then
goto fifteen
if b1 >=89 then
goto stoich
if b1 >=81 then
goto fourteen
if b1 >=68 then
goto thirteen
if b1 >=54 then
goto twelve
if b1 >= 40 then
goto eleven
if b1 >= 30 then
goto ten
if b1 >=27 then
goto nineeight
if b1 >=17 then
goto nine
if b1 >=8 then
goto eight
if b1 >= 1 then
goto seven
goto out
twentytwo:
low c.0
high c.2
low b.0
low b.1
low b.2
low b.3
low b.4
low b.5
low b.6
low b.7
low c.6
low c.7
twentyone:
low c.0
high c.2
low b.0
low b.1
low b.2
low b.3
low b.4
low b.5
low b.6
low b.7
low c.6
toggle c.7
pause 5
toggle c.7
pause 5
twenty:
low c.0
high c.2
low b.0
low b.1
low b.2
low b.3
low b.4
low b.5
low b.6
low b.7
low c.6
nineteeneight:
low c.0
high c.2
low b.0
low b.1
low b.2
low b.3
low b.4
low b.5
low b.6
low b.7
toggle c.6
pause 5
toggle c.6
pause 5
nineteen:
low c.0
high c.2
low b.0
low b.1
low b.2
low b.3
low b.4
low b.5
low b.6
low b.7
eighteen:
low c.0
high c.2
low b.0
low b.1
low b.2
low b.3
low b.4
low b.5
low b.6
toggle b.7
pause 5
toggle b.7
pause 5
seventeen:
low c.0
high c.2
low b.0
low b.1
low b.2
low b.3
low b.4
low b.5
low b.6
sixteen:
low c.0
high c.2
low b.0
low b.1
low b.2
low b.3
low b.4
low b.5
toggle b.6
pause 5
toggle b.6
pause 5
fifteen:
low c.0
high c.2
low b.0
low b.1
low b.2
low b.3
low b.4
low b.5
stoich:
low c.2
high c.0
low b.0
low b.1
low b.2
low b.3
low b.4
toggle b.5
pause 5
toggle b.5
pause 5
fourteen:
low c.2
high c.0
low b.0
low b.1
low b.2
low b.3
low b.4
thirteen:
low c.2
high c.0
low b.0
low b.1
low b.2
low b.3
toggle b.4
pause 5
toggle b.4
pause 5
twelve:
low c.2
high c.0
low b.0
low b.1
low b.2
low b.3
eleven:
low c.2
high c.0
low b.0
low b.1
low b.2
toggle b.3
toggle b.3
ten:
low c.2
high c.0
low b.0
low b.1
low b.2
nineeight:
high c.2
high c.0
low b.0
low b.1
toggle b.2
pause 5
toggle b.2
pause 5
nine:
high c.2
high c.0
low b.0
low b.1
eight:
high c.2
high c.0
low b.0
toggle b.1
pause 5
toggle b.1
pause 5
seven:
high c.2
high c.0
low b.0
If I may make some comments, all of the IF : ENDIF : next IF... can be compacted by using ELSEIF or gotos can be used simply by putting the label on the IF line. Examples:
Lights:
if b1 >= 180 then twentytwo
if b1 >= 167 then twentyone
Lights:
if b1 >= 180 then : goto twentytwo
elseif b1 >= 167 then : goto twentyone
end if
And except for the toggles, that whole lot of code could probably be changed into a (fancy phrase coming...) 'two-dimensional array' of some LOOKUPs(/table/eeprom) that get the port values for use. Portwide pin changes can be made by using {let} pinsB/C = v543210. Example:
Out:
 high b.0
 high b.1
 high b.2
 high b.3
 high b.4
 high b.5
 high b.6
 high b.7
becomes
Out:
dirsB = 255                          'Make pins outputs, needed once only
pinsB = 255                          'Makes all outputs high
7cory7
nick12ab:
Thanks for showing the code:)
As is evident, I only have a rudimentary knowledge of the Picaxe language and poor math skills. I will try your ideas, and see what I get.
This is the second project I have made so far, the first being a high altitude balloon computer which has no flown yet so its not in here.
I'm always open to suggestions/criticisms/gripes/laughs/etc
Thanks again
Cory
For the future, you may also consider the SELECT...CASE program command structure in lieu of numerous IF...THEN tests.
