Hi, my wife and I have to use a stair lift. It is made by a company called Meditek. It can be controlled by
infra red remote controllers which are supplied. There are two buttons on them, up and down!
The buttons have to remain pressed until the lift reaches either limit. What I have in mind is a picaxe
controlled infra red device which again has two buttons, but what I want them to do is:
press button once, and lift will go up or down until it reaches the limits without having to keep the buttons pressed.
This would make it so much easier carrying things up and downstairs.
My question really concerns the IR signal itself. What would be the best way to analyse the signal to find out the
sequence?. I have access to scopes, and I have a logic analyser. Could I just use an ordinary IR diode?
I suppose I could look on a scope to see if there is a carrier signal, like the IR receiver on the axe091.
If someone could point me in the right direction, I would be very grateful, as I've never done anything before using infra red!
regards john
regards john
