i'm quite inexperienced with picaxe, however, i want to use a pulsating led on a project 08m board. this is so tht i can make a proximity sensor. i will have two 08m boards, and on one the pulating led emitter and the other the receiver. the emitter will be on a timer, and so when the time has elapsed, the led will pulse and the receiver (on the separate board) will then recieve the signal. i will hook the receiver up to led outputs so that i can see if it works.
can somebody tell me how to connect the led and the program to pulsate it?
thanks
nimz
thanks
nimz
