mrburnette
We have all seen those too good to be true eBay advertisements; but sometimes I get surprised with a winner. This time it is a dual 2-line LCD. Rather large, probably from a gasoline pump, these are 5V serial displays and are easily interfaced to a PICAXE.
Here is the eBay dealer... 3 displays for $9.99 U.S. dollars. Dealer says he ships 'worldwide' but I can not ascertain the prices outside the U.S. because the eBay tool has locked me into continental only. Anyway, shipping is expensive, so you may wish to team-up with others to order a few and split the shipping cost.
http://www.ebay.com/itm/Lcd-Display-16-x-4-Lines-Micro-Bulk-Lot-3-/350219964507?_trksid=m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D2%26po%3DLVI%26ps%3D63%26clkid%3D6307773599087105463
WARNING: the next statement appears to be incorrect... see post #16. You must open the solder-jumper.
The units ship for 2400 "N" BAUD, but jumper S3 on the rear can be un-soldered (open) to go to 4800 BAUD. I have the DV-16215-1-S2RB datasheet but it is over 1M PDF and I cannot attach to this thread... leave me a message with your eMail and I will send it to you. It is available from http://www.omnidisplays.com/lcd-tft-oled-pdf-character-displays-specs/Displays-Specs/Data-International/Display-Specs-PDF/DV-16215-1-S2RB/ but you must register with them to download.
Attached is some thermometer code I threw together to test both display... all 4 lines. Some may recognize Peter Anderson's algorithm for using a thermistor/resistor for a decent linear temperature range.
http://www.phanderson.com/picaxe/picaxe_thermistor.html
- Ray
View attachment Therm4_08M2_4LineLCD_FT.bas
- Ray
