The attached is an idea of using an 08m2 to write to an eeprom and a 18m2 to read from the eeprom.
I have used multiple devices on an I2C bus before -> picaxe, RTC, eeprom, but never two picaxe chips.
PICAXE doesn't support multi-mastered i2c so you would have problems doing it like that. You'd have even more of a problem if the clock line on the PICAXEs stay as outputs when they are not using the bus.
You would have to at the very lease#t implement some extra handshaking between the two PICAXEs, or check whether the bus is in use by the other PICAXE before the first PICAXE uses the bus.
Yes, I think I've got to try that. Was just hoping to use existing program with minor mods.
A total re-write and clean up wouldn't be a bad thing though. Nowt else to do with this constant rain is there.
