Wouldnt this rule out the use of the page write function on EEPROMS?
from looking at the data sheet on the EEPROM in question it would seem that if you want to write upto 64 bytes in sucession to the page write buffer, then you <b>do not </b> send a stop bit between each of the bytes. the data sheet can be found here: <A href='http://ww1.microchip.com/downloads/en/devicedoc/21203M.pdf' Target=_Blank>External Web Link</a>.
Soo: Can the picaxe not use the page write due to sending out stop bits after every byte? or does the picaxe not send out stop bits, untill the last byte has been sent if at all?
Ben
Edited by - beny1949 on 19/06/2007 19:49:43
