hi,
i know youve all seen this knid of thing beforeso ill keep it breif, i think i need to extend the rang of my bus, my srf008 's worked on short wires for testing, have connected them to the vehicle on the full length wires and no joy. I have lloked through all the past posts and found some good links and i think i need to slow down to I2cslow (167 i think since it is a 28x1 and it doesnt work on them?) i already have 2k8 pull ups, how much current will the transistors in the pic handle and what voltage? some will apparently handle 12v and 15mA which increases range a lot what will pic do? Do i need to increase the value and spread them around, putting one next to each device? If i was to use ferrite beads what value do you think would be good? had a look at galvanic isolators and they look a bit serious. Has anybody got any experience with a bus extender/driver?
Thanks
Matt
Thanks
Matt
