I am trying to build a program & hardware that will connect to my dslr to enable it to take a series of photos for image stacking with camera focus and image spacing controlled by a Picaxe.
Hardware is a NEMA 8 motor, Sparkfun stepper controller board, and a 20X2 board I've repurposed from an LDR audio preamp.
Below is the code that I have written so far that allows me to control the stepper from a Sony remote control. I'm not happy with it because stepper movement is not smooth and continuous and at maximum speed only perhaps half as fast as it would be if I fed the motor controller a continuous series of pulses.
There are certain requirements:
1. Must have a variable step rate that gives me granular control from single-steps at one end of the range to continuous, smooth high speed stepping at the other end of the range.
2. Must keep track of the total step count (in both directions) at all times (which, I believe, eliminates hpwm as an option here) to avoid overrunning the preset minimum and maximum stepper travel points.
Since the Picaxe is not multi-tasking, I have written the program make a finite number of steps per loop with the number of steps per loop increasing as the number of continuous loops increases (with the remote button held down). Letting go of the remote button resets the number of steps per loop back to a single step. This gives me a range of speeds from a single 1/16 step per loop at the beginning of a continuous press up to some user-definable large number of steps per loop after holding the remote button down for a while.
The problem is, the stepper motor movement is jerky because it's stopping at the end of each loop no matter how long I continuously hold the remote button because the program has to exit the loop to check if the move command is still valid.
If possible, I'd like to eliminate that problem, and I'm wondering if I could use an interrupt somehow to allow me to put the stepper into a continuous loop with gradually decreasing PAUSE periods between steps to give me the same control granularity but without the momentary stopping between finite sets of pulses and have it keep running until an interrupt happens (release of remote control button) stops the loop.
This is the program that currently works, but is not as smooth-running as I would like, just wondering if I could use an interrupt in lieu of exiting the stepper loop:
#Picaxe 20X2
#No_Data
#No_Table
SETFREQ m32
Main:
'Control Program Loop
DO
' DO 'wait for command from IR
DO : LOOP WHILE ptr = hserptr
Cmd_Code = @ptrinc
' LOOP UNTIL Cmd_Code <> 255
'Action
IF Cmd_Code = "J" OR Cmd_Code = "K" THEN
IF Cmd_Code = "J" AND Count_Total < Upper_Limit THEN
Direction = CCW
HIGH DirectionPIN
ELSEIF Cmd_Code = "K" AND Count_Total > 1 THEN
Direction = CW
LOW DirectionPIN
ELSE
SEROUT C.7,Baud,(254,192," LIMIT ")
GOTO EndCode
ENDIF
'if first command or position is close to a limit then reset # steps to zero
IF Timer > 1 THEN
Count_Target = 0
ELSEIF Count_Total < Lower_Slowdown AND Direction = CW THEN
Steps_Remaining = Count_Total - 1
Count_Target = Count_Target + 1 MAX Steps_Remaining
ELSEIF Count_Total > Upper_Slowdown AND Direction = CCW THEN
Steps_Remaining = Upper_Limit - Count_Total - 1
ELSE
Count_Target = Count_Target + 1 MAX Max_Steps 'Set number of steps for this iteration based on duration of key press
ENDIF
'Do the Stepping
Count_Stepped = 0
DO
PULSOUT C.1,1
Inc Count_Stepped
LOOP WHILE Count_Stepped < Count_Target
'Calculate current position of stepper & send information to display
IF Direction = CCW THEN
Count_Total = Count_Total + Count_Stepped
ELSE
Count_Total = Count_Total - Count_Stepped
ENDIF
SEROUT C.7,Baud,(254,192," ",#Count_Total,"-",#Count_Stepped," ")
'cleanup
GOTO EndCode
ENDIF
EndCode: 'Prepare for next command and loop to beginning
Timer = 0 'Reset Timer
ptr = hserptr 'clear queued commands to prevent runon
Cmd_Code = 255 'Put null in Cmd_Code
LOOP ' return to Main
