I broke my AXE027 cable :-( Can I repair?
Anobium
I broke the tip off the end of the stereo connector on my AXE027.
Can I simply 'chop' the end off and replace with a new stereo connector?
Before you all wonder how this happened.... I dropped the cable and then ran over the connector with the wheel of my chair. arghhhhh!
I have ordered a new cable but that will take a few days to arrive and I am mid project.....
srnet
I dont see why not.
Although somtimes this type of lead uses a stranded wire re-inforced with nylon or other plastic, these can be a a pain to solder.
Anobium
I shall. I was not sure where the electronics were. Thanks.
Actually, I did expect some comments re my accident! :)
MartinM57
I thought only completely stupid things happened to me, but I can imagine that happening quite a lot...drop something, push back on chair to see where it's gone and run over it :(
It might be possible and you have nothing to lose in trying.
Cut the cable a few inches from the jack plug then cut the cable open to work out which wire colour goes to tip, ring and sleeve using a continuity tester.
