gangstanuggets
#picaxe 18M2
#no_data
symbol baud = N2400
symbol oled = C.3
symbol seconds = b0
symbol mins = b1
symbol hour = b2
symbol day = b3
symbol date = b4
symbol month = b5
symbol year = b6
symbol control = b7 ; Control register for RTC
symbol debounce = b8 ; Button debounce variable
; Set up I2C for RTC DS3231
init:
hi2csetup i2cmaster, %11010000, i2cslow, i2cbyte ; Set RTC slave address
;writei2c 0, ($00, $43, $16, $06, $23, $11, $24, $10)
pause 800
serout c.3, n2400, (254, 1) ; Clear OLED screen
pause 100
; Display initial OLED message
;serout oled, baud, (254, 128, " Cat Feeder ")
;serout oled, baud, (254, 192, " Press to Feed ")
; Uncomment to set the clock
; goto set_clock
; Read RTC values
hi2cin 0, (seconds, mins, hour, day, date, month, year)
pause 100
; Convert BCD values to ASCII for display
bcdtoascii seconds, b10, b11
bcdtoascii mins, b12, b13
bcdtoascii hour, b14, b15
bcdtoascii date, b16, b17
bcdtoascii month, b18, b19
bcdtoascii year, b20, b21
; Display day of the week on OLED
; select case day
; case 1: serout oled, baud, (254, 128, " Mo ")
; case 2: serout oled, baud, (254, 128, " Tu ")
; case 3: serout oled, baud, (254, 128, " We ")
; case 4: serout oled, baud, (254, 128, " Th ")
; case 5: serout oled, baud, (254, 128, " Fr ")
; case 6: serout oled, baud, (254, 128, " Sa ")
; case 7: serout oled, baud, (254, 128, " Su ")
; endselect
; Display date on OLED
;serout oled, baud, (254, 133, b16, b17, ".", b18, b19, ".20", b20, b21)
; Display time on OLED
serout oled, baud, (254, 193, b14, b15, ":", b12, b13, ":", b10, b11)
SerOut c.3, n2400, (254, 128, "Weight:", #w0, " g ")
; Check button for manual feeding
button C.5, 1, 255, 0, debounce, 1, manual_feed
; Automatic feeding at 7:00 AM
if hour = $16 and mins = $44 and seconds < $02 then
gosub automatic_feed
pause 500
manual_feed:
; Button is pressed - rotate servo for manual feeding
serout oled, baud, (254, 128, " Feeding... ")
servo b.3, 148 ; Initialize servo
servopos b.3, 224 ; Rotate servo clockwise
pause 2000 ; Rotate for 1 second
servopos b.3, 148 ; Stop servo
pause 3000 ; Small delay to prevent accidental re-triggering
debounce = 0 ; Reset debounce variable
automatic_feed:
; Automatic feeding at scheduled time
pause 2000 ; Rotate for 2 seconds
set_clock:
; Write current time and date (e.g., 8:30 AM on Saturday, 23rd November 2024)
let seconds = $00 ; 00 seconds
let mins = $37 ; 30 minutes (BCD format)
let hour = $10 ; 8:00 AM (24-hour format)
let day = $06 ; Saturday (Day 1 = Monday, Day 7 = Sunday)
let date = $23 ; 23rd (BCD format)
let month = $11 ; November (BCD format)
let year = $24 ; Year 2024 (BCD format)
let control = %00010000 ; Enable 1Hz square wave output (optional)
hi2cout 0, ($00, $08, $16, $06, $23, $11, $24, $10)
serout oled, baud, (254, 1, " Clock Set! ") ; Notify clock is set
pause 2000
Symbol CLK = C.2
Symbol DIN = C.0 : Symbol DIN_PIN = pinC.0
Symbol weightRaw = w0 ' Store raw weight reading
Symbol tareValue = w1 ' Store tare value (for zeroing)
Symbol calibrationFactor = w2 ' Store calibration factor (used for conversion)
;Define bitCount for loop
Symbol bitCount = w3 ' Define the bitCount variable
PowerOnReset:
Input DIN
High CLK
Pause 5000
Low CLK
' Set a calibration factor (to be determined through experimentation)
calibrationFactor = 500 ' Example value (adjust after calibration)
' Set the tare value (offset with no weight on load cell)
tareValue = 0 ' Set the tare value to 55000 (your measured offset)
MainLoop:
Do
' Read HX711 and process data
Gosub Read_HX711
' Subtract the tare value to get the actual weight
weightRaw = w0 - tareValue ' Subtract tare value to get net weight
' Apply calibration factor to convert raw data to readable weight
weightRaw = weightRaw / calibrationFactor ' Apply calibration factor
' Display the weight on the OLED
SerOut oled, 9600, (254, 128) ' Move cursor to top-left of OLED
SerOut oled, 9600, ("Weight: ", #weightRaw, " g ") ' Display weight in grams
' Send the processed weight data over serial for debugging
SerTxd("Weight (Processed): ", #weightRaw, " g", CR, LF)
Pause 1000 ' Wait 1 second before next reading
Loop
' Subroutine to read HX711 and get raw data
Read_HX711:
Gosub Read_Channel_A_Gain_128
Return
' Subroutine to read data from HX711 (Gain = 128 for Channel A)
Read_Channel_A_Gain_128:
Gosub Read_24bits
PulsOut CLK, 1
Return
' Subroutine to read 24 bits of data from HX711
Read_24bits:
Do : Loop Until DIN_PIN = 0 ' Wait for data to be ready
w0 = 0 ' Initialize w0 for raw data storage
For bitCount = 1 To 24
PulsOut CLK, 1 ' Clock the HX711
w0 = w0 + w0 + DIN_PIN ' Shift in the data bit-by-bit
Next
Return
#no_data
symbol baud = N2400
symbol oled = C.3
symbol seconds = b0
symbol mins = b1
symbol hour = b2
symbol day = b3
symbol date = b4
symbol month = b5
symbol year = b6
init:
pause 800
pause 100
; goto set_clock
; Read RTC values
pause 100
; select case day
; endselect
pause 500
manual_feed:
automatic_feed:
set_clock:
pause 2000
Symbol CLK = C.2
PowerOnReset:
Input DIN
High CLK
Pause 5000
Low CLK
MainLoop:
Do
Gosub Read_HX711
Loop
Read_HX711:
Return
Gosub Read_24bits
PulsOut CLK, 1
Return
Read_24bits:
Next
Return
