Hi All
Have being playing around with the Dorji DRF1278DM with the intention of using it
for a battery powered remote sensor unit
I have the units talking to each other with the following using the 9600 braud rate
just toggling leds at both ends
My question is I have used the following without sucess
Is the problem just a timing issue or is the approch (miss interputation of the manual) wrong for waking up the slave
I can not use the hserin/out from the master as they controll the nextion display
any comments welcome
regards john
high b.7
home:
serin A.0,T9600,b0
pause 450
sertxd(#b0," ")
if b0=100 then
goto light
light:
toggle b.6
toggle b.7
goto home
#rem
high b.6
for b0=1 to 100
serout C.6,T9600,(b0)
pause 500
pulsout B.7,1000
next b0
toggle b.6
'Waking up the 28x2 with the dorji DRF1278DM
#Picaxe 28X2 '
'Master 40x2
serout A.0,9600,("ZZZZZZZZ")
'slave 28x2
top:
hsersetup B9600_8,%10
HIntSetup %00100001
SetIntFlags %00000001, %00000001
disablebod
sleep 0 'sleep until interrupt occurs to save battery power
enablebod
goto top
Interrupt:
setintflags off
hsersetup off ' Master is using the hser pins to run nextion display
hserFlag = 0
flag0=0
sertxd("IN Interrupt")
'read sensors serial out values to master via serial commands
Return
regards john
