Hi all,
I am trying to control a relay with an 08M2. The intent is to power cycle a broadband router (12V, 1A power supply)
I would like to buy an off the shelf solid state relay because I haven't got time to make one and for other reasons I have no control over. Ideally I would like the relay to be normally close (NC) so that I can disconnect the Picaxe circuit for tinkering/maintenance and still have the router on.
However there is much less choice of NC relays than Normally open (NO)
Is there a way to setup a control circuit (using power from the load side, I an not worried about separating the two circuits) to turn a NO relay into a NC one? Intuitively this should be possible with a combination of a transistor and resistors but I couldn't find a fitting example on the internet or on the forum.
I am not good at thinking in "transsistor language" so any advice would be very welcome.
Thanks in advance
Riccardo
Thanks in advance
Riccardo
