First, make sure that there aren't already and LCDs that have inverted colours and that there aren't any options for this in the properties dialogs for the LCDs.I mean color inversion.
Yes, have you done the stuff in my last post?I want a black and white LCD. I mean the LCD background will be black and the text will be in white.
I don't know how as I don't use the program, but shouldn't it just be done the same way as the background colour?How to edit colours in library files and which library files. Earlier I had converted a Green LCD to a Blue LCD in proteus, but the text was black. Now I want to convert the LCD to a background Black and text white. I have converted the background to black, but I want to know how to convert the text to white. Any text sent to the LCD should appear in white.
Can you make copies of all the files for one particular LCD display. Then on the originals, change the background colour to something else. Then use the comp command in the Command Prompt to find the differences between the current and old copy of the files and this will locate where the background colour settings are stored. Once you've located the background colour setting, the foreground colour setting can't be far away.I thought it the same way, but the foreground colour option is disabled.
I took this long to reply because I was hoping that someone who knew more about this would step in and help, but as they haven't then...I don't know. The foreground colour change option is disabled.
