I am trying to use a voltage splitter with a photo resister to turn on the 08M2 chip at a certain darkness. Once on, the the outputs drive a mosfet to control 10mm LED's which are tied to the voltage rails separately.
In action, the voltage to the 08M2 rises above 4V as it gets dark and the chip turns on somewhere after that but less than 4.5V. I know the 08M2 output is the same voltage that drives the chip.
The output goes to the mosfet gate and switches it on.
Problem: mosfet must operate in ohmic region vs saturated region at this gate voltage because led intensity is weak until gate voltage gets closer to 4.5+V
How do I get 08M2 to switch on at higher voltage? Thus output to gate is higher and and LED is bright.
